Activity › Forums › Apple Final Cut Pro Legacy › exporting for PC 16:9 square pixel
  • exporting for PC 16:9 square pixel
    Posted by Nick Welch on August 16, 2008 at 10:43 am
    Just need to know what is the best way to export from FCP to PC in widescreen
    Is there a way to export PAL widescreen square pixel i.e 1024×576. I need to get my head around this issue.
    My editor is used to working at 16:9 – for tv, but the work i’m doing is for PCs
    I’d be extremely grateful for an answer on how to do this in FCP.
    Best wishes,
    Nick Welch
    Nick Welch replied 18 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • Daniel Low
    August 16, 2008 at 11:07 am
    What format is required for the PC – AVI? WMV? Quicktime? MPEG-2?
    What format do you work with in FCP?
    If your editor is used to working with 16:9 content then he should have no problem doing what you need.
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Nick Welch
    August 16, 2008 at 12:37 pm
    Hi Daniel,
    many thanks for responding.
    I doon’t mind if the export is down in mov or avi PAL. normally the editor exports in MOV. However i just need to know that can he export a mov at 1024×576 (16:9) for PC…is there any rules for exporting for PC?. I will then compress movie using sorenson squeeze.
    kind r
    Nick
    Best Wishes,
    Nick Welch
  • Daniel Low
    August 16, 2008 at 1:44 pm
    There are no rules as such. Most PC’s have Quicktime installed these days. Make sure that you are using a CODEC that is available in the PC version of Quicktime. For example you couldn’t use ProRes or DVCPROHD. I’d suggest PhotoJPEG at 76% quality, or above.
  • Arnie Schlissel
    August 16, 2008 at 1:47 pm
    Why do you think you need it in square pixels? There are very few square pixel formats for SD, and those few are outside of the rec 601 broadcast spec.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Sean Oneil
    August 18, 2008 at 11:46 pm
    Exporting for a PC does not require square pixels. For all QT movies playback aspect can be controlled by hitting Command-J, Video Track, Visual Settings.
    Sean
  • Daniel Low
    August 19, 2008 at 7:45 am
    “For all QT movies playback aspect can be controlled by hitting Command-J, Video Track, Visual Settings”.
    Only if you have QT Pro.
  • Nick Welch
    August 19, 2008 at 9:59 pm
    Best Wishes,
    Nick Welch
