Activity Forums Apple Final Cut Pro Legacy Exporting for DVD
  • Exporting for DVD
    Posted by Zach Pape on April 26, 2016 at 6:27 pm
    Hey there. It’s been years since I’ve had to export for DVD. I’ve got a sequence, 60 mins, thats 1920×1080.
    I know the fastest export here is to just do current settings, but is there an alternative to this? Something that works as fast but gives a smaller file size. I was trying to export this to a hard drive with 70gbs on it and apparently that wasn’t enough room.
    Thanks for your help!
    Shane Ross replied 10 years, 4 months ago 3 Members · 2 Replies
  • Mark Suszko
    April 26, 2016 at 7:46 pm
    Assuming you’re working in FCP7? You could try making a more compressed mpeg3 in Compressor first, or shrinking the file size in MPEG Streamclip first. Changing audio from stereo to mono will save a little bit of space. Usually not enough to make or break, except when you’re on the very edge of capacity. You could also buy 2-layer blank media.
  • Shane Ross
    April 26, 2016 at 8:37 pm
    If you use DVD Studio Pro and Compressor…just export a REFERENCE QT, that’ll be very small and point to the media on your media drive. Then take that into Compressor to Compress for DVD, and then author with DVD SP.
    Throw out that REF QT when you are done. It’s job will be complete.
    Shane
    Little Frog Post
