Activity › Forums › Adobe Premiere Pro › Exporting for Australian DVD format.
  • Exporting for Australian DVD format.
    Posted by Paul Copeland on April 18, 2015 at 2:50 pm
    Hello. Newbie here.
    I want to export my movies for the Australian DVD format. These Dvd’s will be of our grandchildren.
    There are so many options that I am quite overwhelmed!
    What format should I export to?
    The imported files are 1920 by 1080
    Data rate 19551 kbps
    Total rate 19684kps
    Frame rate 29 fps
    Audio
    Bit rate 132kps
    Channels 2 (stereo)
    Audio sample rate 48 kHz
    Many thanks for your assistance.
    Paul.
    Paul Copeland replied 11 years, 5 months ago 2 Members · 2 Replies
  • Jeff Pulera
    April 20, 2015 at 1:59 pm
    Hi Paul,
    It seems that you are in the US, correct? The NTSC video standard is used in the US, while Australia (and UK and many other countries) use the PAL format. NTSC is 720×480 at 29.97fps while PAL is 720×576 at 25fps. You could export from an NTSC source to a PAL format, but no need for that – PAL DVD players will play NTSC DVDS, as the conversion hardware is built into PAL DVD players. So just make an NTSC DVD and you ought to be fine. Converting NTSC to PAL via software will not yield very good results anyway, without specialty software.
    I don’t know if your source is 1080i or 1080p, but export from Premiere using the “MPEG-2 DVD” format, and choose an appropriate preset, either “NTSC DV Widescreen” for 1080i source or “NTSC DV Widescreen Progressive” with 1080p source. Take the results into Adobe Encore to author and burn to DVD.
    Jeff Pulera
    Safe Harbor Computers
  • Paul Copeland
    April 21, 2015 at 1:09 am
    Hey Jeff.
    Many thanks for your thorough explanation.
    I am actually from Australia 🙂
    I will have a go following your instructions.
    Seeya.
