Activity Forums Apple Final Cut Pro Legacy Exporting for a projector
  • Exporting for a projector
    Posted by Michelle Orpe on August 19, 2011 at 2:49 pm
    Hi
    I’ve read a few posts about this but I’m still a bit confused as to what will be best. I have a project that is going to be shown on a projector through a laptop the project consists of:
    Pictures at 1024×1509, 1288×1024 etc which I have put motion to
    Text
    Motion Template 1920×1080
    The sequence settings are: 720×576 CCR601/DV Pal (5:4)
    I am in England. What should I export this as for this to be shown on the Laptop/projector?
    Thanks for helping
    Michelle
    Michelle Orpe
    http://www.michelleorpe.com
    Jonan Grobler replied 15 years ago 2 Members · 1 Reply
  • Jonan Grobler
    August 23, 2011 at 10:06 am
    Well, it depends on the specs of the projector itself.
    Seeing as you’re working with HD content though, I would definitely recommend changing the sequence settings to say 1280×720 (HD (960×720) (16:9)). This should be fine for most projectors.
    Also, your photograph sizes aren’t optimal for the higher 1920×1080 resolution, you would have to zoom them up for that. So stick with 1280×720.
