Activity Forums Adobe Premiere Pro Exporting .flv file
  • Exporting .flv file
    Posted by Andy Crowson on April 26, 2011 at 11:12 am
    Pretty basic this, but how do I export my movie from final cut so that it is a .flv file to use on my new website? I have FCP 6, and also Adobe CS5
    Thanks a lot,
    Andy
    Jeff Greenberg replied 15 years, 4 months ago 3 Members · 4 Replies
  • Todd Kopriva
    April 26, 2011 at 11:44 am
    You can use Adobe Media Encoder to convert a movie into an FLV file.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Andy Crowson
    April 26, 2011 at 3:19 pm
    Thanks. But now I’m a little confused as to whether to convert to the f4v (media encoder’s default setting)or the flv format (which web designer has instructed) – which is better, and briefly why? Can you point me in the direction of an article to read as I’ve had a good look and can’t find the information I’m after.
    Cheers,
    Andy
  • Todd Kopriva
    April 26, 2011 at 3:37 pm
    There’s information about F4V and FLV files here.
    They each have pros and cons. Here are the primary differences off the top of my head: FLV files can play in older versions of Flash Player, and they can contain an alpha channel. F4V files use more efficient compression.
  • Jeff Greenberg
    April 27, 2011 at 4:04 am
    F4v is using the h.264 codec – Mpeg4 part 10
    FLV is using the On2 VP6 codec – from Sorenson.
    Generally, the FLV works with older flash (and weaker systems)
    F4V is using h.264 which is a more efficient codec at the same bandwidth.
    I fed into google, FLV vs. F4v and got this article (which is mostly right – it’s wrong about what kind of codec the F4V is)
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
