Activity Forums Adobe Premiere Pro Exporting FLV crashes
  • Exporting FLV crashes
    Posted by Matt Davy on July 28, 2009 at 11:54 am
    I have a 500mb avi file that I need to encode into an FLV file.
    I brought it into premiere pro cs3, placed on the timeline and then used the Media Encoder to create an FLV. I used the settings of original resolution (950×640) bitrate of 2000kb/ps. There is no audio with this clip.
    When I export it using these settings it goes fine until about the 20% mark. Then it slows down until at around 26% the percentage is no longer visibly incrementing. It will occasionally jump maybe one or two percent.
    I continue doing other processes and premiere pro will eventually become unresponsive, it will not maximise anymore and in the end I am forced to End the Process using Task manager.
    The clip is only 14 seconds long and has been created in 3ds Max.
    I have 110Gb free on my C: drive and over 300Gb free on my E: drive (where it is exporting to)
    I eventually gave up and used the Adobe Flash Video Encoder using exactly the same settings. It took about 20 seconds and the output FLV is fine.
    What I want to know is why premiere cannot handle this? I have used the media encoder countless times with no problems, although it has always seemed slow… I have changed my Media Cache to be on my E: drive as this always has lots of space just in case, as I read disk space can be an issue.
    Please, any ideas?
    I can’t really sit and watch it export all the way through as I have countless other things to do at the moment.
    Cheers,
    Matt.
    Matt Davy replied 17 years, 1 month ago 1 Member · 1 Reply
  • Matt Davy
    July 31, 2009 at 8:59 am
    I am still having this problem, it only seems to occur when trying to encode video exported from 3ds max in uncompressed avi format. I have managed to get around it by using Targa sequence’s instead. I am still a little puzzled, as it can’t be the file size as I’ve worked with much much bigger files before with no issues.
