Activity Forums Apple Final Cut Pro Legacy Exporting Final Cut Pro 5 audio file to Soundtrack Pro
  • Exporting Final Cut Pro 5 audio file to Soundtrack Pro
    Posted by David H dennis on June 8, 2005 at 3:29 pm
    It was supposed to be easy – right-click on the timeline, select “Send to” and “Send to Soundtrack Pro Audio File Project”.
    Unfortunately, no matter what I do, that particular option is grayed out, and it seems like the workflow for the multitrack project is a bit more complicated.
    I’ve looked through the manual and don’t even see information on the “Send To” option in the index. The Soundtrack Pro manual mentions it but doesn’t give any information as to why it might be grayed out.
    Can some kind soul give me the answer?
    Many thanks.
    D
    John Pale replied 21 years, 3 months ago 2 Members · 1 Reply
  • John Pale
    June 8, 2005 at 6:05 pm
    Send to Soundtrack Pro Audio File Project is for single clips, so if you have more than one selected it will be greyed out.
    If you want to do a multitrack project, you need to select Send To Soundtrack Pro Multitrack Project.
    Does that work for you? It should.
    If you want to work on the whole sequence, select it in the browser
