Activity Forums Adobe After Effects Exporting files with transparency
  • Exporting files with transparency
    Posted by Steven Morgans on May 6, 2014 at 10:30 am
    I am exporting files from AE as .mov and with RGB+Alpha which makes the files fine but has a large file size, I need to make these under 30MB is there anyway to make them smaller and preserve transparency or a different file format that would still have transparency and a small file sise?
    Todd Kopriva replied 12 years, 4 months ago 2 Members · 1 Reply
  • Todd Kopriva
    May 6, 2014 at 2:46 pm
    Why do you need these files to be small? Typically, you only need an alpha channel when the files are being in the next stage of a post-production pipeline, and size does not tend to be a consideration then. Size should only matter for final delivery formats.
    That said, try the PNG video codec in a QuickTime container. It tends to create files that are about half the size of files created with the Animation codec, and it’s still a lossless compression scheme.
    After Effects team blog
