Activity Forums Adobe After Effects Exporting FCP to AE problem
  • Exporting FCP to AE problem
    Posted by Craig Swanson on September 23, 2008 at 9:06 pm
    After exporting an image sequence out of FCP I’m having trouble with my frame rate in after effects. I have footage with 32 frames but it shows up in after effects only at 26 frames. It’s probably something stupid but I think I had all the bases covered.
    My settings for the FCP tiff export is 23.976. After the export I check and see I have 32 frames. I then import into AE and interpret my footage at 23.976. Comp settings are 23.976. but the footage only shows up as 26 frames. Anyone have an idea I can try out?
    The reason I’m using a tiff image sequence is because I’m batch treating the footage in illustrator before bring into AE.
    Craig
    Macbook Pro 17
    10.5.4
    2.6 ghz
    4 gigs ram
    GeForce 8600 GT 512 mb
    HD One 8 drive Raid 5
    QT 7.5
    FCP 6.04
    Martti Ekstrand replied 17 years, 12 months ago 2 Members · 3 Replies
  • Craig Swanson
    September 23, 2008 at 9:44 pm
    Dave,
    when I export the tiff sequence there is a box to enter the frame rate. I enter 23.976. My fcp sequence setting is 23.98 (prores hq). I also tried 23.98 for my tiff export but get the same issue.
    Craig
    Macbook Pro 17
    10.5.4
    2.6 ghz
    4 gigs ram
    QT 7.5
    FCP 6.04
  • Craig Swanson
    September 23, 2008 at 10:16 pm
    Dave,
    I’ll investigate to see if there is somewhere that 29.97 got into the mix. Original footage was shot on the red one camera at 23.98. I transcoded to prores at that frame rate and thought I used it throughout the process but it looks like that wasn’t the case.
    Craig
    Macbook Pro 17
    10.5.4
    2.6 ghz
    4 gigs ram
    QT 7.5
    FCP 6.04
  • Martti Ekstrand
    September 24, 2008 at 4:29 pm
    Quick question: why a tiff image sequence? Instead of a Animation QuickTime file which is basically a tiff sequence in a QT wrapper.
    cheers
