Activity Forums Apple Final Cut Pro Legacy Exporting FCP Marker XML
  • Exporting FCP Marker XML
    Posted by Paul Gregory on September 21, 2012 at 1:12 pm
    Hello,
    I am trying to figure out if there is a way of exporting only the marker XML from FCP 7. My current method is importing the whole sequence XML into Premiere Pro, then through exporting media you can save separate marker XML.
    Can any one shed any light on the situation…
    Thanks in advance.
    Paul
    Paul Gregory replied 13 years, 11 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    September 21, 2012 at 5:28 pm
    If the markers are within clips you could make those markers subclips, and export that XML. You can also export sequence markers as a text file. That’s in the file/export submenu.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Paul Gregory
    September 25, 2012 at 1:29 pm
    Thanks for your time Jerry.
    Paul
