Activity Forums Apple Final Cut Pro Legacy Exporting FCP 5 Sequence to Motion
  • Exporting FCP 5 Sequence to Motion
    Posted by Tmorris6936 on June 8, 2005 at 2:36 pm
    I have a finished sequence in FCP 5. I got o send to Motion project as I have done a hundred times in 4.5HD. When it opens up in Motion the alpha channels are not interpreting the way that they should. All of the layer show up in the Motion timeline the same way that they do in FCP 5. I have selected each individual layer one by one and changed the blend mode and cannot get the alpha to come in the way that it should. Like I said earlier, I have done this hundreds of time in the previous versions of FCP and Motion and think that I have covered all of my basis. Any thoughts??
    Here is what the image should look like ( as it is in FCP 5)
    https://www.nightglass.com/Stockton/thunderFCP.jpg
    and this is what I get in Motion
    https://www.nightglass.com/Stockton/thundermotion.jpg
    I know that this is an Alpha interpretation issue but I have turned Motion inside out and can’t get it to work.
    Thank you in advance.
    Tmorris6936 replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
