Activity Forums Media 100 exporting edls to Final Cut 4.5
  • exporting edls to Final Cut 4.5
    Posted by Peter Shwartz on September 16, 2005 at 11:32 pm
    I’ve searched for this throughout cow without luck so apologies to any willing to repeat themselves, but I can’t figure this out. I’m trying to export a simple edl, no effects.
    Kim Rowley replied 20 years, 11 months ago 3 Members · 2 Replies
  • Matt Short
    September 17, 2005 at 5:09 pm
    Open the program you wish to export & choose File>Print to EDL.
  • Kim Rowley
    September 18, 2005 at 3:19 pm
    That is correct, print to EDL but then choose to save the file in the CMX format. That way your reel numbers transfer correctly. If you save it as a SONY 5000 EDL, the reel numbers are translated as 001, 002 etc. With the CMX 3400 or 3600 format FCP asks for the reel numbers in the same way as you numbered them in M100 and you can batch digitize your program flawlessly.
    Dual 2.7 GHz G5, 4GB RAM, ATI Radeon 9650, Xserve RAID, AJA IO, 2 20″ Cinema Display, FCP 5.02, OS X10.4.2
