Activity Forums Apple Final Cut Pro Legacy exporting DVCProHD 1080p from timeline
  • Chris Tompkins
    July 21, 2010 at 1:19 pm
    That’s what it supposed to do. HD, When full raster is 1920 X 1280
    Chris Tompkins
    Video Atlanta
  • Jeremy Garchow
    July 21, 2010 at 3:22 pm
    [Chris Tompkins] “1920 X 1280”
    1920×1080.
    That’s Quicktime doing the real time anamorphic stretching. Your clip is still 1440×1080.
    Jeremy
  • Chris Tompkins
    July 21, 2010 at 3:46 pm
    That’s what I meant.
    Thanks.
    Chris Tompkins
    Video Atlanta
  • Dovydas Vilkelis
    July 21, 2010 at 6:14 pm
    Okay, so there is another problem. I export some clips for use in Nuke,
    and it is stretched too much. No matter what pixel aspect ratio I make in Nuke project, square or 1.333. Is it possible to avoid quick time stretching to 1920×1080? Or maybe there is another solution?
    __
    DTG Video
    Video production
    http://www.dtg.lt
  • Jeremy Garchow
    July 21, 2010 at 7:12 pm
    Are you changing anything when you export?
    Should be File > Export > QuickTime Movie
    Make sure ‘make self contained’ box
    Is checked.
  • Dovydas Vilkelis
    July 21, 2010 at 7:19 pm
    I do exactly what you wrote. When I watch video with QT player, it’s ok.
    __
    DTG Video
    Video production
    http://www.dtg.lt
  • Jeremy Garchow
    July 21, 2010 at 7:26 pm
    Nuke must not understand the aspect ratio of DVCPro Hd.
  • Dovydas Vilkelis
    July 22, 2010 at 12:12 pm
    Nuke understands it, when I import video just after transferring from camera.
    __
    DTG Video
    Video production
    http://www.dtg.lt
  • Jeremy Garchow
    July 22, 2010 at 12:23 pm
    So, after you log and transfer, if you take one of those quicktimes to Nuke, it’s ok. But if you export from FCP, it’s no good.
    Can you take a screenshot of your sequence settings?
  • Dovydas Vilkelis
    July 22, 2010 at 5:31 pm
    I don’t think it’s sequence issue, because FCP makes settings, when I insert some footage on timeline. I just don’t want QT stretch, because after that some problems occurs in Nuke. It thinks footage is 1920×1080, but with 1.33 pixel apsect ratio.
    __
    DTG Video
    Video production
    http://www.dtg.lt
