Activity Forums Apple Final Cut Pro Legacy Exporting DV PAL 16×9 at highest quality and deinterlace
  • Exporting DV PAL 16×9 at highest quality and deinterlace
    Posted by Tomas Valenzuela on March 16, 2013 at 7:21 pm
    I would appreciate if someone could advice on steps and settings for exporting an edit of a documentary from FCP 7 at the highest quality and de-interlace it for the color mix stage. The documentary is intended initially for film festivals and hopefully broadcast and DVD.
    The footage has been shot on DV PAL Anamorphic (hence final dimensions should be 1024×765).
    I have read FCP’s guide, forums and many articles online.
    What I finally understand is that I should export as follows:
    File > Export > Using Quicktime conversion
    Video settings > Compression Type: DV-PAL > Frame rate: Current or 25 > Compressor quality: Best > Scan Mode: Interlaced (Since FCP does not a good job on this) > Aspect ratio: 16×9 (here?)
    Video Size > Pal 720×576 16:9 (here too?) > Preserve aspect ratio: NO (no need?) > De-interlace: (Since FCP does not a good job on this)
    This works, when I open the file in quicktime with property inspector all details are OK. But the image doesn’t show side to side horizontally (on the left and right there is a 2 black pixels width vertical gap). Also, and I know i’ll be told off, when I export the same way but with Compression to NONE, looks like heaven, but I know the file size is impossibly BIG to work on, is this the only reason for not using NONE.
    On the subject of De-interlacing, I have found on the internet the answer might be:
    BorisFX or RevisionFX best for FCP
    McBob (a script not for FCP no?) that uses motion compensation
    Is there a plugin for FCP that uses motion compensation?
    I will leave it up till here, many thanks for your time,
    Tomas
    Computer specs:
    Model Name: MacPro3,1
    Processor Name: Quad-Core Intel Xeon
    Processor Speed: 2.8 GHz
    Number Of Processors: 2
    Total Number Of Cores: 8
    L2 Cache (per processor): 12 MB
    Memory: 2 GB
    Bus Speed: 1.6 GHz
    Boot ROM Version: MP31.006C.B05
    SMC Version (system): 1.25f4
    Chipset Model: ATI Radeon HD 2600
    Type: Display
    Bus: PCIe
    Slot: Slot-1
    PCIe Lane Width: x16
    VRAM (Total): 256 MB
    Vendor: ATI (0x1002)
    Device ID: 0x9588
    Revision ID: 0x0000
    ROM Revision: 113-B1480A-252
    EFI Driver Version: 01.00.252
    Displays:
    Cinema:
    Resolution: 1680 x 1050
    Depth: 32-Bit Color
    Core Image: Hardware Accelerated
    Main Display: Yes
    Mirror: Off
    Online: Yes
    Quartz Extreme: Supported
    Rotation: Supported
    Display Connector:
    Status: No Display Connected
    Tomas Valenzuela replied 13 years, 6 months ago 2 Members · 2 Replies
  • Rafael Amador
    March 18, 2013 at 11:05 am
    [Tomas Valenzuela] “exporting an edit of a documentary from FCP 7 at the highest quality and de-interlace it for the color mix stage.”
    You don’t need to de-interlace for Color Correction.
    [Tomas Valenzuela] “xporting an edit of a documentary from FCP 7 at the highest quality and de-interlace it for the color mix stage. The documentary is intended initially for film festivals and hopefully broadcast and DVD.
    The footage has been shot on DV PAL Anamorphic (hence final dimensions should be 1024×765).”
    If you are going Broadcast and DVD, keep standard PAL 720×576.
    1024×576 Squared Pixels is for web download.
    Forget about “QT Conversion”.
    If you have edited the PAL DV stuff on a PAL DV sequence, export a QT movie with the current settings:
    Export > Quick Time Movie..
    rafael
  • Tomas Valenzuela
    March 22, 2013 at 12:07 am
    Hi Rafael,
    Thanks for your reply.
    I am exporting for color mix, so what you suggest is to export as 4:3 interlaced from Export > QTM? Not 16:9?
    Whichever way, when I export through QTM as anamorphic or as current settings (like my sequence in FCP) the result in Quicktime property inspector shows the ACTUAL export as 1049×576, and when I try 4:3 the result shows 789×576.
    I appreciate any further comments, many thanks, Tomas.
