Activity Forums Apple Final Cut Pro Legacy Exporting DV-NTSC 4:3 = slightly stretched
  • Exporting DV-NTSC 4:3 = slightly stretched
    Posted by Nate Hanson on November 6, 2007 at 11:12 pm
    When exporting from FCP I’m getting a slightly squished image. The original footage looks fine, but after FCP exports it, the footage is ever so slightly stretched horizontally.
    It isn’t 16:9…not even close. Just slightly wider than 4:3.
    Any ideas? I used Easy Setup for DV-NTSC.
    Nate
    Nate Hanson replied 18 years, 6 months ago 2 Members · 2 Replies
  • Richard Harrington
    November 7, 2007 at 2:21 pm
    See aspect ratio question above
    If you want it to look 16:9 you have to compress it and set it properly in display size
  • Nate Hanson
    November 7, 2007 at 8:01 pm
    Ok, I read the other thread and watched the pixel ratio video. I’m still unclear on some things. Let me clarify:
    I’m not trying to make a widescreen video, I just want to turn my footage from my camera into a regular video.
    The footage looks normal (aspect ratio) when editing in FCP.
    When I export it, the final product is *slightly* stretched wide. It isn’t noticeable unless you have seen the original footage to compare it to. I don’t understand why there would be any difference between my original footage and the final product.
    I used the FCP “Easy Setup” for DV-NTSC.
    I used Export -> Using Quicktime Conversion…
    What am I missing?
