Activity Forums Apple Final Cut Pro Legacy Exporting dropframe or non-dropframe
  • Exporting dropframe or non-dropframe
    Posted by Carl Whitney on September 6, 2007 at 11:14 am
    I have been asked to export from a timeline video footage drop frame. Is there a setting in FCP6 that allows this?
    Carl
    Emkayprods replied 19 years ago 2 Members · 2 Replies
  • Emkayprods
    September 6, 2007 at 12:33 pm
    You’ll have to change the properties for the timeline itself.
    Make a duplicate of the timeline and go to sequence settings (command-O) and select the tab for timeline options. There is a check box for drop frame next to the starting timecode — make sure it is selected.
    Your export will then have drop frame timecode. Be sure to check your starting timecode, though. If you were aiming for a particular frame to start the action, you may have to make an adjustment or two to make sure you start where you are supposed to and end where you are supposed to.
    Good luck.
    -mk
  • Emkayprods
    September 6, 2007 at 12:35 pm
    Good luck.
    -mk
