Activity Forums Apple Final Cut Pro Legacy Exporting DCPro HD to Quicktime
  • Exporting DCPro HD to Quicktime
    Posted by Keith Miller on February 5, 2008 at 7:36 pm
    I have been editing in FCP 5.0.4 in 1080i from tapes shot on DVCpro tape. The sequences have been exporting fine but as of two days ago they fail to export correctly. Instead they export only about 75% of the sequence. The sequence is 20 minutes and the export (which takes about 4 hours) ends up being 16 minutes. I am exporting to the compression it was shot on (1080i60) and edited in. This has also happened subsequently on shorter sequences (a 4 minute sequence outputs a 3 minute quicktime). In both cases cutting off the last quarter.
    I tried creating a new project and starting from scratch with a copy of the sequence, but no luck.
    Any suggestions how to solvethis?
    Dale Larsen replied 18 years, 5 months ago 2 Members · 1 Reply
  • Dale Larsen
    April 3, 2008 at 6:15 pm
    Just curious if you found the answer to this issue. I am having the same situation.
    my 90 sec clip always exports 45 sec of it, IF I use DVCPRO codec. normal export if different codec.
