Activity Forums Adobe After Effects Exporting comp with different texts
  • Exporting comp with different texts
    Posted by Jurjen Versteeg on June 9, 2009 at 11:07 am
    Hello,
    I was wondering if there is any way to export a comp multiple times, but automatically with different texts in it.
    So let’s say I have a composition called “Fashion student” with a text layer and I want to export this composition, but in every export I want a different student name in it. Like using an array or something?
    Is there a script, preset or setting which can solve this?
    Thanks in advance,
    Jurjen
    Roland R. kahlenberg replied 17 years, 3 months ago 2 Members · 3 Replies
  • Roland R. kahlenberg
    June 9, 2009 at 12:03 pm
    You’ll need Javascript for this. Try posting at the COW’s AE Expressions Forum as you may get a better response there. For the good ol’ fashioned, hand eye coordination way, you can render multiple instances of a single comp with a batch render with each instance having its own IN-Out points.
    HTH
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
  • Jurjen Versteeg
    June 9, 2009 at 12:51 pm
    Posted the message in AE Expressions.
    But, actually still don’t know what you mean by giving it an In and Out point…
    June 9, 2009 at 1:04 pm
    [Jurjen Versteeg] “what you mean by giving it an In and Out point…”
    For each render instance in the Render Queue, within the Render Settings dialog, you can manually set an IN and OUT to define the range within your timeline that will be rendered out.
    HTH
    RoRK
