Activity › Forums › Adobe Premiere Pro › Exporting Closed Captions from Premiere Pro (Format Options)
  • Exporting Closed Captions from Premiere Pro (Format Options)
    Posted by Andrew Saliga on June 29, 2016 at 7:25 pm
    I know the ability to export closed captions from Premiere Pro CC is relatively new… Are the only container format options MOV and MXF? I received a spec sheet from Chase Bank, and they require the spot be delivered as an MP4, WebM, and OGG, all with caption data embedded AND as a sidecar file. I can’t seem to find a solve for the embedded versions. Telestream’s MacCaption seems to be a possible option, but I can’t seem to tweak video encode specs.
    Thanks.
    Andrew Saliga
    I/O Specialist/Editor
    Steelehouse Productions
    http://www.steelehouse.com
    Andrew Saliga replied 10 years, 2 months ago 2 Members · 5 Replies
  • Chris Borjis
    June 29, 2016 at 10:14 pm
    To my knowledge, none of those file types support embedded captions (MP4, WebM, and OGG)…side car yes but not embedded unless they are burned into the video itself.
  • Andrew Saliga
    June 29, 2016 at 10:21 pm
    That was my understanding as well. I’ve since been able to do the MP4 and WebM encodes via Sorenson Squeeze Pro 11. QT7 Pro doesn’t detect the CC track, but Telestream’s Switch player does detect it in the metadata. I’m using their free demo for testing.
    Now if I can just encode the OGG file.
    Andrew Saliga
  • Chris Borjis
    June 29, 2016 at 10:23 pm
    Interesting. Sometimes it takes a different encoder to get those options.
  • Chris Borjis
    June 29, 2016 at 10:25 pm
    I know that an mpeg transport stream can have embedded captions, but for some
    reason Adobe doesn’t support that and sometimes I get that requested as a broadcast
    deliverable and have to work around it.
  • Andrew Saliga
    June 30, 2016 at 7:59 pm
    In case anyone else ends up with this same question, here is the resolve.
    I was able to encode OGG files with Theora video and Vorbis audio via VLC on Windows.
    Andrew Saliga
