Activity Forums Adobe Premiere Pro Exporting clips from a sequence
  • Exporting clips from a sequence
    Posted by Mike Hennelly on February 21, 2012 at 3:54 pm
    Here is the issue. I have a 2 hour video broken up into 99 segments in order to make clips for an index. I have a marker at the beginning of each clip identifying the number it is.
    The problem is when I have to send these clips to Adobe Media Encoder, I have to physically remember each start and end timecode number from the sequence in order to punch them into the export dialogue box and then send it to the queue in Media Encoder.
    Isn’t there a way I can mark the in and out point on the sequence and have the export box show the in and out points and send to queue?
    Here is the process that I am doing now…
    1. Marker is at start of clip – (let’s say 00:40:03 – clip number 2) I have to remember this timecode or write it down.
    2. I put the cursor bar at the end of the clip (00:57:06)
    3. I hit (control M) on the keyboard.
    4. The Export box appears, I hit the (Set out point) button, because that is where the cursor was on the sequence and is now stationed there on the timeline bar under the window.
    5. I click on the numbers on the left side of the window and enter in the number that I wrote down from step 1 above.
    6 Then I click on the queue button to send to Media Encoder.
    What I would like to know is if there is a way to mark, in and outs on the sequence, and click on export and have those values already be there instead of having to write down the numbers 99 times.
    Thanks for any help!
    Mike
    Mike
    Custom Video Productions
    Conshohocken, PA
    Mike Hennelly replied 14 years, 7 months ago 3 Members · 3 Replies
  • Jon Merrifield
    February 21, 2012 at 9:09 pm
    Have you tried nesting your sequence into new sequences that are timed for your specific outputs?
    ie: Seq10 (or whatever) (your master sequence nest is your source) is timed to start and end where you need and the timecodes of this sequence can be customized your you can use the source data.
    Jon Merrifield
    VFX Artist / Supervisor
    PELi Studios, Austin TX
  • Gabriel Sanchez
    February 22, 2012 at 1:32 pm
    Only fit the timeline work area to the in and out points of each segment you made, export selecting “Only Work area” in the Adobe Media Encoder. Do de same for each segment.
    Regards
  • Mike Hennelly
    February 22, 2012 at 2:21 pm
    That was the trick! Thanks so much!
    Mike
    Conshohocken, PA
