Activity › Forums › Apple Final Cut Pro Legacy › Exporting clean graphics
  • Exporting clean graphics
    Posted by Dan Kallaur on December 23, 2009 at 2:59 pm
    I am attempting to export a sequence to iDVD using QT. Sequence is 1280 x 720. Graphics look fine on timeline. When I view the dvd, the images are fine, but the graphics look terrible. Any suggestions on settings to fix this? Can it be the compressor setting, QT or iDVD?
    Jaron Halmy replied 16 years, 9 months ago 3 Members · 2 Replies
  • David Bogie
    December 23, 2009 at 4:19 pm
    IDVD cannot do anything with that kind of format. it is going to convert everything to standard def at MPEG2. You’re wasting your time and resources working at 1080 and then scaling down to SD lots of detail is getting thrown away.
    bogiesan
  • Jaron Halmy
    December 27, 2009 at 6:25 am
    What type of QT? Be sure to export using “Quicktime Movie” not “Quicktime Compression.” You may be adding an unnecessary compression step.
