Activity Forums Maxon Cinema 4D exporting C4d objects to AE layers?
  • exporting C4d objects to AE layers?
    Posted by Steve Roberts on January 26, 2013 at 3:35 pm
    Apologies: I’m not at the C4D/AE computer, so I can’t check the Help or test out theories.
    With R12, would it be possible to render/export an image in layers, but with each *object* on a separate layer in PS or AE?
    I would then like to sequence the layers in AE, revealing them one layer at a time, so each object is revealed as each layer is revealed.
    I’d the process to be as automated as possible, since I expect to have a lot of objects, and therefore a lot of layers. I may use mograph to create spheres at object vertices, then reveal the objects by flashing on one sphere at a time. (flash on six spheres in sequence to reveal a cube, for example)
    If it’s not possible to separate the objects in the export to PS/AE, might it be possible to use object IDs and *animate* the object ID value in AE to reveal one object at a time? (an AE question, of course)
    Steve
    Steve Roberts replied 13 years, 7 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    January 26, 2013 at 7:08 pm
    I don’t know of any way to automate this. Best I can think of is to render an object buffer (alpha) for each object and then luma matte them in AE. In that case you’d need to render a clean background plate, and you’d still have a problem if your objects overlap.
  • Steve Roberts
    January 28, 2013 at 2:51 am
    Thanks, Adam.
    Steve
