Activity Forums VEGAS Pro Exporting Blu-Ray Format
  • Exporting Blu-Ray Format
    Posted by Jerry Pope on January 10, 2013 at 6:37 pm
    I was wondering if anyone knew how to take mp4 720p/60fps video and put this on a blu-ray. I’m new to editing an this is the first problem I ran into. Any advice will help. SONY VEGAS PRO 11
    John Rofrano replied 13 years, 7 months ago 2 Members · 5 Replies
  • John Rofrano
    January 10, 2013 at 11:54 pm
    [Jerry Pope] “I was wondering if anyone knew how to take mp4 720p/60fps video and put this on a blu-ray. I’m new to editing an this is the first problem I ran into. Any advice will help. SONY VEGAS PRO 11”
    Create a new project in DVD Architect with Disc Format: Blu-ray Disc and Project Video Format: AVC 1280×720-60p, 16:9 and drop your footage on the menu and burn the disc.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jerry Pope
    January 13, 2013 at 5:08 am
    Can I edit the video in DVD Architect or do I have to do that in Vegas Pro?
  • John Rofrano
    January 13, 2013 at 2:27 pm
    [Jerry Pope] “Can I edit the video in DVD Architect or do I have to do that in Vegas Pro?”
    No, you can’t edit the file in DVD Architect. DVD Architect is a DVD/Blu-ray authoring program. You would have to edit the file in Vegas Pro but your question was: “…if anyone knew how to take mp4 720p/60fps video and put this on a blu-ray.” so I assumed that you already had an edited file and just wanted to put it on Blu-ray.
    If you need help rendering a file from Vegas Pro to a Blu-ray format then that’s a different question.
    ~jr
  • Jerry Pope
    January 13, 2013 at 8:52 pm
    Ok that’s exactly waht I would like to do. All in one program and keep it a one step process as far as, editing and rendering without switching programs. So how would I keep my video @ 720p/60fps when I want to render and burn in Vegas Pro?
  • John Rofrano
    January 14, 2013 at 11:07 am
    [Jerry Pope] “So how would I keep my video @ 720p/60fps when I want to render and burn in Vegas Pro?”
    Select Sony AVC and start with the Blu-ray 1920×1080-24p, 16 Mbps video stream template. Press the Customize Template… button and change the Video Format to High definition (1280×720) and the Frame Rate to 59.940 (Double NTSC) and save it with the name Blu-ray 1280×720-60p, 16 Mbps video stream. Then render with that template.
    It should look like this:
    ~jr
