Activity › Forums › Adobe Premiere Pro › exporting big movie in chunks.
  • exporting big movie in chunks.
    Posted by Ben Oliver on January 12, 2012 at 7:58 pm
    I need to export 17 hours of HD footage into 5 minute web chunks. nothing fancy, just corporate meetings….is there a way to do this automatically?
    The video is currently in one hour chunks.
    Ben Oliver replied 14 years, 8 months ago 2 Members · 4 Replies
  • Jeff Pulera
    January 12, 2012 at 8:39 pm
    Hi Ben,
    While the “chopping up” part is not automated, you could add each segment to the Queue in Adobe Media Encoder and then they’d all render out as a batch, rather than encoding one at a time and having to baby-sit the job
    Jeff Pulera
    Safe Harbor Computers
  • Ben Oliver
    January 12, 2012 at 8:43 pm
    Do they each have to be in a sequence?
  • Jeff Pulera
    January 12, 2012 at 8:47 pm
    Each 5-minute video does not have to begin as a unique sequence – a longer source clip can be used, and then just make the Work Area Bar in Premiere 5-minutes long, and then use Export “Work Area” and just keep moving the bar and adding more segments to the Queue.
    Jeff Pulera
  • Ben Oliver
    January 13, 2012 at 2:01 pm
    What I ended up doing, which worked pretty well was placing my 17 hours of footage into one sequence.
    I then ran through it cutting it into rough 5 minute pieces.
    I then ran back through and subclipped everything into a bin.
    I then queued each of them into AME with the correct render settings.
    and, 12 hours later, the render was finished.
    With an addition of sending a bunch of clips or sequences to batch render, that would be amazing. But it didn’t crash. I guarantee putting 225 clips through compressor would have crashed!!!
    WAHOO!
    -Ben
