Activity Forums Avid Media Composer exporting avid sequence as quicktime file
  • exporting avid sequence as quicktime file
    Posted by Raju Bhai on September 8, 2006 at 6:17 pm
    how would I export my timeline sequence on Avid as a quicktime file that I can import into Final Cut Pro? Or, better yet, is there a way to play my clip data in final cut pro? The media was captured from DVC Pro-50 tapes directly into Avid by somebody else for me, but he doesn’t know how I can get the media in Final Cut Pro so I can edit it there. I know as long as I can get them as quicktime files then they will play in Final Cut.
    Michael Hancock replied 19 years, 12 months ago 2 Members · 1 Reply
  • Michael Hancock
    September 8, 2006 at 7:34 pm
    To take footage directly from Avid to FCP take a look at Automatic Duck.
    https://www.automaticduck.com/products/pifcp/
    It’s designed to do this and runs about $500. Otherwise, you can export each clip individually by selecting every clip in a bin and choose File–>Export. Choose Quicktime, go to your options and set the Codec to Animation for best quality. Choose a folder to output to then be prepared for a really long wait.
    If you’ve cut a sequence, simply mark In and Outs on the areas of the sequence you want to export, select the tracks you want to export, and do the same as before–File–>Export, choose Quicktime, Use Marks, Use Enabled Tracks, select the right field order, Animation Codec, select the proper size, Video and Audio (if you have video and audio), then select a folder and hit OK. Take a nap. Knit a sweater. Read War and Peace, because this will also take awhile, depending on the length of the sequence.
    Warning: You won’t have timecode on any exported clips this way. Doing an UpRez or any type of batch capture in your FCP system will be impossible via the Quicktime export method. To be honest, it would be a lot faster and easier just to Capture and Cut on FCP or Avid instead of trying to port between the two. Unless you buy Automatic Duck. It should help (I’ve never used it, but it gets really good reviews everywhere).
    Good luck!
    Mike.
