Activity Forums Adobe After Effects Exporting AVI without it majorly reducing the Quality!
  • Exporting AVI without it majorly reducing the Quality!
    Posted by Sean Harper on August 31, 2008 at 4:02 am
    ok, I have a perplexing problem-
    Every Time I export in AVI or movie it reduces the quality a butt load and I have no idea why! Shouldn’t AVI be lossless!?
    if there’s a way to export AVI without it reducing quality please tell me
    Brendan Coots replied 18 years ago 2 Members · 1 Reply
  • Brendan Coots
    September 1, 2008 at 7:27 am
    AVI is not “lossless.” AVI is just a container like Quicktime. All it does is store your video/audio, and present it to players that recognize the AVI format. Within the AVI file, your video is compressed with a particular codec that the AVI format supports, such as Divx or Uncompressed. It is the codec you decide to use within the AVI file that determines the quality, and you probably are using a really crappy codec instead of uncompressed.
    If you aren’t using the render queue (that is, if you are using the File>Export option) you need to start using the render queue (Composition>Add To Render Queue). Beyond that, you need to explore the various codec and quality settings once you select AVI as your output container format, and you will find what you need. If you don’t know enough about codecs to decide which is the best option for your needs, search Google for something like “AVI codec options” until you find what you need.
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
