Activity › Forums › Apple Final Cut Pro Legacy › exporting AVI out of Final Cut Pro 5
  • exporting AVI out of Final Cut Pro 5
    Posted by Tim on August 17, 2005 at 10:12 pm
    Hi Folks,
    Wondering if anyone else is having a problem exporting an Uncompressed AVI over 4GB out of FCP. When the clip(file) becomes over 4Gb it only will play back 15sec of clip yet the clip size looks like it should be. Has anyone else run across this…..
    Ercumend replied 21 years, 1 month ago 3 Members · 2 Replies
  • Todd Beabout
    August 17, 2005 at 10:24 pm
    In general AVI’s don’t play nice with QuickTime. If an image sequence is a possibility, I would reccomend going that path. You can probably find a PC app that will create an uncompressed AVI out of an image sequence and then you’re golden. I have never personally gotten an AVI to work right with QuickTime, but I’m not saying it isn’t possible.
    -Todd Beabout
    Vazda Studios
  • Ercumend
    August 17, 2005 at 11:00 pm
    If you are a bug reporter too apple Problem ID: 4135137
    if you are not
    Welcome to the Apple Bug Reporter Your last login: 27-Jun-2005 11:31 PM
    Problem ID: 4135137
    Title:Exporting QT Dv video using avi conversion (most quality) in FCP !
    State:Closed Created Date: 01-Jun-2005 01:03 AM
    01-Jun-2005 01:03 AM Ercumend KOCANA:
    If you ever export a quicktime dv video longer than 20-25 minutes using quicktime conversions and choose avi most quality in Final Cut Pro. You can just see first 4 or 5 minutes of the video. If you import this avi video to Final cut its looking shorter too. But the size of the video is big like the video is for 20 minutes. QT 7.0 is even worse. It s not even playing the file and giving an error. I will send this msj to Quicktime too.
    Ercumend KOCANA
    Sata Production
