Activity › Forums › Adobe Media Encoder › Exporting AVI from a Mac
Posted by Mandla Bolekaja on January 31, 2013 at 11:25 pmHow do I export an AVI file from a Mac?
Using CS6, Media Encoder 6.0.2 on Mac OS 10.8.2.Thanks
MMB
2.8 Quad-Core, 18 GB Ram, CS6, Mountain LionMandla Bolekaja replied 13 years, 3 months ago 3 Members · 3 Replies -
Todd Kopriva
February 1, 2013 at 5:26 amInstall Flip4Mac or a similar utility to give QuickTime the ability to create AVI files.
After Effects team blog
Wallace Karraker
May 24, 2013 at 12:00 amIf you’re on a Mac you can re-enable AVI exports from QuickTime 7 on OSX Lion or later…
The gist of the message is this…
In order to enable one of the “legacy video codecs” open /Applications/Utilities/Terminal, copy/paste the appropriate line (or all of them) into a terminal window, and hit return. The effect is instantaneous.
qtdefaults write LegacyVideoCodecs ApplePlanarRGB enabled
qtdefaults write LegacyVideoCodecs SorensonVideo enabled
qtdefaults write LegacyVideoCodecs SorensonVideo3 enabled
qtdefaults write LegacyVideoCodecs AppleBMP enabled
qtdefaults write LegacyVideoCodecs AppleCinepak enabled
qtdefaults write LegacyVideoCodecs AppleH261 enabled
qtdefaults write LegacyVideoCodecs AppleH263 enabled
qtdefaults write LegacyVideoCodecs AppleMotionJPEGA enabled
qtdefaults write LegacyVideoCodecs AppleMotionJPEGB enabled
qtdefaults write LegacyVideoCodecs ApplePNG enabled
qtdefaults write LegacyVideoCodecs AppleNone enabled
qtdefaults write LegacyVideoCodecs AppleVideo enabled
qtdefaults write LegacyVideoCodecs AppleGraphics enabled
qtdefaults write LegacyVideoCodecs AppleTGA enabled
qtdefaults write LegacyVideoCodecs AppleTIFF enabled
qtdefaults write LegacyVideoCodecs AppleComponentVideo enabled
qtdefaults write LegacyVideoCodecs AppleJPEG2000 enabled
qtdefaults write LegacyVideoCodecs ApplePixlet enabledIf you also want to enable all of the “legacy audio codecs” you can copy this line to your terminal:
qtdefaults write LegacyAudioCodecsEnabled yes
Mandla Bolekaja
May 24, 2013 at 8:46 amThanks Wallace, this is very helpful.
MB
2.8 Quad-Core, 24 GB Ram, CS6, Mountain Lion
