Activity › Forums › Apple Final Cut Pro Legacy › Exporting audio with SMPTE
Posted by Aryn Leigh on February 18, 2010 at 2:39 amSimple question: (Maybe not-so simple answer)
I am using FCP and need to export audio tracks w/SMPTE code.
How do you do?
Bouke Vahl replied 15 years, 11 months ago 4 Members · 9 Replies -
Michael Gissing
February 18, 2010 at 3:16 amIf you export an OMF it has the info on where the files sit in a sequence timeline so an OMF will import into an audio system with the file correctly synced to the sequence timecode on the correct track.
Or do you mean a file like broadcast wav with embedded timecode metadata? More info on what you are trying to do will help.
Aryn Leigh
February 18, 2010 at 3:20 amYes it’s an audio file to be sent for transcription. So yes, a wav file with embeded metadata. It will be read only by the transcribers.
Michael Gissing
February 18, 2010 at 3:53 amCan the transcribers play quicktime files? You can export the audio in a quicktime wrapper as later versions of quicktime player can read the embedded timecode. You could also provide a burn in on the video track or do they need to extract the timecode info automatically from the file? Most transcription services that I use take quicktime files.
Otherwise can they read broadcast wav and its embedded timecode?
Bouke Vahl
February 18, 2010 at 8:09 amIt’s in fact easy:
https://www.videotoolshed.com/product/44/ltcgenerator/3‘>
https://www.videotoolshed.com/product/44/ltcgenerator/3Import a QT, and you get a SMPTE LTC audio track.
Paste that in your timeline or in your QT and you’re done.If you have a batch of clips to do, contact me and i’ll write something that will do the pasting for you.
Bouke
smart tools for video pro’s -
Adam Driscoll
September 8, 2010 at 6:56 pm@ Vahl
This program works great but I’m looking for a program that also carries over the audio (converts multi-channel audio quicktime with source timecode to BWAV file with same source timecode). Any thoughts?
Bouke Vahl
September 9, 2010 at 7:39 amwave to BWF is simple, get qtchange from my site.
https://www.videotoolshed.com/product/42/qtchange
However, it only does stereo or mono.
If could make it to work on any amount of channels, but that would require a day or so of coding.
How important is it to have poly files instead of multiple Mono?Bouke
smart tools for video pros -
Bouke Vahl
September 9, 2010 at 7:47 amoops, should have been:
QT to BWF instead of Wave to BWF…Bouke
Adam Driscoll
September 9, 2010 at 7:33 pm@ Bouke,
I saw this tool but yes we would need all channels to transfer straight across. Here’s an example quicktime movie we’d need converted:
https://www.box.net/shared/rjyvy980m8
The goal would be to produce a broadcast wave file with the same timecode stamp, same frame rate, same clip name, etc and all mono channels transferred across (up to 8).
Bouke Vahl
September 10, 2010 at 4:39 pmAdam,
Downloading now.
I’m pretty sure i can make something, but it depends if you want P or M files.
Since this thread is very old, contact me direct at bouke at videotoolshed dot comBouke
