Activity Forums Adobe Premiere Pro Exporting Audio With AAC Codec
  • Exporting Audio With AAC Codec
    Posted by Tyler Leisher on July 29, 2008 at 9:31 pm
    For some reason when I try to export my film to a .mov (or any other format for that matter) and I choose the audio section it doesn’t give me the choice of any codec to use.. I can only have uncompressed audio.
    Furthermore, there’s no option to set the bit rate…
    How can I set the bit rate to 128 kbps and use the AAC codec for my audio when exporting to a .mov?
    Simon Bonner replied 18 years, 1 month ago 3 Members · 2 Replies
  • Mike Velte
    July 30, 2008 at 10:58 am
    Are you in the “Adobe Media Encoder”? The only QT format worth using is H264 and it has all the audio options.
  • Simon Bonner
    July 30, 2008 at 4:11 pm
    If you have quicktime pro, you could run it through that programme after your Prem render.
    Simon Bonner
    youtube.com/simonsaysFX
