Activity Forums Apple Final Cut Pro Legacy Exporting audio levels to OMFs?
  • Exporting audio levels to OMFs?
    Posted by Erin Casper on August 15, 2008 at 9:15 pm
    Does Final Cut export rubberbanding information to OMF files?
    I’m sending work to ProTools, and would like to know that my audio work (level keyframes, pans, etc.) will stay intact.
    I am working on FCP v. 5.1.4.
    Erin Casper replied 18 years, 1 month ago 3 Members · 6 Replies
  • Walter Biscardi
    August 15, 2008 at 9:20 pm
    [Erin Casper] “Does Final Cut export rubberbanding information to OMF files?
    I’m sending work to ProTools, and would like to know that my audio work (level keyframes, pans, etc.) will stay intact. “
    It does, but the audio designers I work with do not bring that information in with the projects. They start from scratch.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Erin Casper
    August 15, 2008 at 9:31 pm
    Thanks for the quick reply! I thought it did, too. Does it do it by default or is there a Preference I need to set? I’ve exported some OMFs to my re-recording mixer, and he says the info is NOT coming over. He’s pretty experienced with his side of the equation and, frankly, his set-up (software, hardware) is much more professional than where I’m coming from. I’m inclined to think I’m doing something wrong or there’s something I need to set in FCP or in a sequence preset. Can anybody shed some light on this?
  • Walter Biscardi
    August 15, 2008 at 9:34 pm
    [Erin Casper] “Thanks for the quick reply! I thought it did, too. Does it do it by default or is there a Preference I need to set? I’ve exported some OMFs to my re-recording mixer, and he says the info is NOT coming over.”
    In FCP 6 there are check boxes when you do the File > Export > OMF on whether to include levels or not. Been so long since I used FCP 5.1 I have no idea.
    Read my Blog!
  • Erin Casper
    August 15, 2008 at 9:40 pm
    Good to know! Thank you very much, Walter!
  • Bill Dewald
    August 15, 2008 at 9:41 pm
    Actually, this feature was new to 6.0.
    You’ll need Automatic Duck to have the info carry over in 5.1.
  • Erin Casper
    August 15, 2008 at 9:48 pm
    Excellent. Thank you, Bill! I’ll look into adding this to our workflow.
