Activity Forums DaVinci Resolve Exporting Audio from Resolve -> Audacity ?
  • Exporting Audio from Resolve -> Audacity ?
    Posted by Michael Reed on July 9, 2020 at 1:21 am
    How do I export my audio only (all tracks) from Resolve, in a format I can edit in Audacity, please?
    I would assume I reimport to Resolve in the same way as any media file.
    \”Commitment is the enemy of resistance, for it is the serious promise to press on, to get up, no matter how many times you are knocked down.\” – David McNally
    \”There are no rules in filmmaking. Only sins. And the cardinal sin is dullness.\” – Frank Capra
    Matthew Jeschke replied 3 months, 1 week ago 4 Members · 3 Replies
  • Michael Gissing
    July 9, 2020 at 2:07 am
    You can export tracks as wav files which Audacity can import. However, given Fairlight in Resolve is vastly more suited to audio editing and mixing, I’m perplexed as to why you would use Audacity? I regularly help people learn to make podcasts and I recommend they use Fairlight in Resolve and not Audacity which for me is an ordinary edit tool. I do use Audacity occasionally to make an mp3 file.
    Fairlight is an amazingly powerful editor, with heaps of built in plugins, plus you can use VST plugins. It has very powerful EQ, processing and full automation including being able to sub bus signals to create stem mixes. Having track based, bus based and clip based processing, it really is the best audio system of any NLE
  • Anya Spa
    April 23, 2026 at 9:17 pm
    I use Audacity instead of fairlight because my laptop is old, and the audio bugs in davinci resolve, it allows me to see the clips but when reproducing them they shut down after a few seconds… that doesn’t happen in audacity… but I have to align the clips to the moving parts of the video so… that’s my reason to use both software, even when fairlight might be better..
  • Matthew Jeschke
    May 28, 2026 at 2:11 am
    I think there maybe a way to round trip files… Say if you’re working with a sound engineer who doesn’t necessarily have resolve. We were looking into that so we could use Adobe Audition for some of the sound design but decided to stick inside fair light for now.
    It’s worth noting I had similar challenges with fair light until they came out with version 19, which I assume you’re already running if not newer.
