Activity › Forums › Apple Final Cut Pro Legacy › Exporting audio from FCP as AIFF playable on CD players
  • Enzo Tedeschi
    January 16, 2006 at 9:59 pm
    Export the AIF as you normally would, and then use iTunes / Toast etc to create an audio CD out of it.
    The only thing to watch out for is that audio on video files is 48khz sampling rate, CDs are only 44khz. There will need to be a conversion somehwere along the line, but your burning software may take care of that.
    Otherwise convert to 44khz as you export from FCP.
    Enzo Tedeschi
    ____________________________
    Editor
    Sydney, Australia
  • Bee More
    January 18, 2006 at 7:09 pm
    Thanks so much for your help. Worked perfectly. Don’t know why I didn’t think about using iTunes…
