Activity Forums Adobe Media Encoder Exporting Audio at specific setting
  • Exporting Audio at specific setting
    Posted by Mark Mcconnell on March 19, 2018 at 3:57 pm
    Hi there,
    Hopefully someone can answer these questions for me? I’m using Premiere Pro, After Effects and Media Encoder and have to deliver to a client files with the following specs:-
    Wrapper:MXF op-1a
    Codec: XDCAM 50 mbps (Mpeg-2) 4:2:2
    1920×1080 interlaced
    Framerate: 50 fps
    Audio: 16-20-24 bit 48 Khz -6dBFS
    Additional Requirements:1 minute of bars and tone 1KHz @ -6dBFS
    When I send the files to Media Encoder I can set a preset for the pictures (MXF op-1a XDCAM 50 mbps 4:2:2) without a problem however the test file I sent had audio levels all over the place.
    The timeline I exported my final edit from on Premiere had bars and tone set to 24 bit / 48 Khz -6dBFS… but the audio on the edit was all over the place when delivered from Media Encoder.
    My questions are…
    1] When I create the my sequence in Premiere should I set the audio levels at 0 / zero and then adjust the final levels in Media Encoder?
    2] If so …where do I adjust my audio levels in Media Encoder…I don’t seem to be able to see them.
    Or alternatively…
    1] Should I create my sequence in Premiere Pro with the clients audio specs? 24 bit / 48 Khz -6dBFS. ?
    2] And then export the final file fromPremiere with matching the sequence settings?
    m
    Mark Mcconnell replied 8 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
