Activity Forums Adobe Premiere Pro Exporting Apple ProRes 422 from Premiere in Windows.
  • Exporting Apple ProRes 422 from Premiere in Windows.
    Posted by Juan manuel Palomino domínguez on July 1, 2016 at 6:33 pm
    Hi. I need to export a video with these settings:
    Apple ProRes 422 (HQ)
    ITU-R BT.709 color space
    VBR expected ~220 Mbps
    1920 x 1080 square pixel
    Original Aspect Ratio
    Áudio 5.1
    Channels: L, R, C, LFE, Ls, Rs
    AIFF or .WAV uncompressed
    LPCM ou Big Endian ou Little Endian, 16-bit ou 24-bit, at least 48kHz with 128 Kbps in any one
    Áudio 2.0 Stereo
    Channels: L e R Stereo, não pode ser DUAL MONO.
    Arquivo: .AIFF o .WAV uncompressed
    Any kind of help would be really apreciated. Thank you!
    Joy Kawk replied 9 years, 1 month ago 4 Members · 4 Replies
  • Joy Kawk
    July 28, 2017 at 11:05 am
    [Dave LaRonde]
    Re: Exporting Apple ProRes 422 from Premiere in Windows.
    by Dave LaRonde
    on Jul 2, 2016 at 4:12:16 am
    You will need to find a Windows version of the ProRes encoder. They’re out there.
    Hello Sir. Could you please tell me the name of this kind of encoder? I ….just can’t find them….(sad face)
  • D j Harris
    July 28, 2017 at 1:53 pm
    Hi Juan,
    Had this request from a client a while back and was recommended either this:
    https://www.cinemartin.com/cinec/
    or this:
    https://www.acrovid.com/download.htm
    In the end the client didn’t need pro-res, but I tested FootageStudio 4k and it seemed to produce good results from a hi-res export through Adobe Media Encoder (I think I did Cineform 10 bit, or maybe DNXHD from Adobe) then compressed that in FootageStudio 4k. I don’t know off the top of my head if it will do the audio formats you need but it’s worth a shot.
    (I think there is also a way of doing it for free with FFmpeg but I didn’t test that)
    Hope that’s of some help.
    Dan
  • Shane Ross
    July 28, 2017 at 3:49 pm
    If this is for delivery to a TV network, none of those encoders will work. They produce a “hacked” version of the codec that networks reject. Sorry, Apple doesn’t officially license the ProRes encoder for Windows…except on high end software like Scratch.
    Nope, for ProRes encoding that passes muster, you need to have a Mac to transcode your output, and software the includes ProRes, like Compressor.
    Shane
    Little Frog Post
  • Joy Kawk
    July 29, 2017 at 3:18 am
    [Shane Ross] “If this is for delivery to a TV network, none of those encoders will work. They produce a “hacked” version of the codec that networks reject. Sorry, Apple doesn’t officially license the ProRes encoder for Windows…except on high end software like Scratch.
    So sad…. I’d have to buy a MAC…. Thanks very much for this!
