Activity Forums Adobe After Effects Exporting animation with an appropriate Quicktime codec without frame and sync issues
  • Exporting animation with an appropriate Quicktime codec without frame and sync issues
    Posted by Vel Gol on April 14, 2018 at 11:19 pm
    So I rendered out my 3D animated short from AE and imported to Audition only to find out that he audio is out of sync with the video. When I import just the sound (wav) into AE everything is in sync. Obviously the issue is the exported video (Quicktime .h264). Did .h264 compress any frames and that why it’s out of sync? What could be the reason? (it’s 24fps just like everything in AE)
    Also please recommend me a good quicktime codec for exporting from AE in order to be able to view the animation without losing frames.
    For my final export from AE (video and audio) I intend to use DNxHD which will end up on Youtube and Vimeo.
    Vel Gol replied 8 years, 5 months ago 3 Members · 4 Replies
  • Steve Bentley
    April 15, 2018 at 12:54 am
    It may have to do with your audio hardware. 48k audio needs special harware to sync to video. Pretty much any computer can do 41k. This also goes for programs. Some handle decoding 48k better than others.
    Try is at both and see what happens.
  • Walter Soyka
    April 16, 2018 at 10:25 am
    Does the footage play in-sync in After Effects (when cached)?
    If you’ve imported your animation as an image sequence into After Effects, make sure that you’ve interpreted it at the correct frame rate. Right-click the footage item in the project panel, select “Interpret Footage” and double-check the frame rate.
    [Steve Bentley] “48k audio needs special harware to sync to video.”
    I disagree. Most video standards specify 48 KHz audio, and most NLEs default to 48 KHz audio.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Vel Gol
    April 17, 2018 at 11:52 am
    It plays in sync when it’s inside of AE, all of the shots are image sequences imported into AE and interpreted as 24fps. I’m using Adobe Audition for the audio. I haven’t managed to fix it yet but I think we’ll manage. Can you guys recommend me a format/codec for exporting all of these 32bit uncompressed exrs (everything is computer generated)? As I said I’m planning on exporting a Quicktime DNxHD 444 10bit but I want to learn about other options. It’s going to end up on Vimeo and Youtube and I also need to make a DCP later on but that’s another topic.
  • Vel Gol
    April 17, 2018 at 12:28 pm
    I’m testing the DNxHD right now, the colors look a bit too red than what I see in my image sequences. Is that possible? I’m using AE 2017 CC but when I use it to export I always get a wrong gamma so I save it down to CS6 which works fine except for the red saturation.
