Activity › Forums › Adobe Premiere Pro › Exporting animation problem CS6 mac
  • Exporting animation problem CS6 mac
    Posted by Mir Geevan on August 18, 2014 at 5:11 pm
    Hello-
    Posted this on the Adobe Premiere forum, apologies for duplicating question but it’s not getting much response so I try here…
    I’ve been rendering and rerendering, reading options in forums and still am getting nowhere. I’m using CS6 on a Mac. Please help…..
    Objective:
    Export a high quality video file for Vimeo. I have read to use the h.264 codec, and that is what I’ve been using.
    My imported footage:
    720×540 @ 30fps square pixels, targa stacks from AE (progressive).
    Premiere export settings:
    720×540 @ 30fps, square pixels, progressive, h.264 codec, mV4, TV-NTSC, profile-high, level-4.1, render at max depth, VBR 2 pass- 10/20, keyframe dist-1, no multiplexer, max render quality, no frame blend
    I can export the files (mV4 or mp4) but can’t play them back in VLC, QT, etc. All I get when playing back is a message that says ‘error’. I can play it back in Premiere though. All software is updated.
    Question:
    Should I be using a standard setting instead of my custom setting?
    I read somewhere about re-scaling my footage at 90% and fitting it in a standard format, is this the best option?
    Any ideas about what I’m doing wrong?
    I’d like to preserve everything ‘as is’ if possible and create the highest quality video that I can upload to Vimeo.
    Thanks in advance for any suggestions…..
    Mir Geevan replied 12 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
