Activity Forums Adobe Photoshop Exporting Animation From Photoshop
  • Exporting Animation From Photoshop
    Posted by Brett Leach on June 20, 2012 at 6:11 am
    Please, somebody help me!
    I’m losing my mind trying to export an animation from photoshop. If this helps, I am going to use it in aftereffects. Its an eye blink and mouth movement sequence. Its 90 frames but is the same 30 frames repeated 3 times. Currently I have it saved as a .psd file. I’m am trying to export it so I can used it in aftereffects. I could not successfully get it to run in aftereffects whether I imported as a composition or footage. Rendering and exporting worked, however it seems as if there is no way to keep a transparent background. I have to have a transparent background as the eyes and mouth are going to go on a face. What are my best options here? Thanks in advance for the response.
    Richard Harrington replied 14 years, 3 months ago 2 Members · 1 Reply
  • Richard Harrington
    June 20, 2012 at 1:19 pm
    Change render settings to a codec tht supports an alpha then turn it on (like animation or DPX)
