Activity Forums Adobe After Effects Exporting animation as HD in AE?
  • Exporting animation as HD in AE?
    Posted by Matthias on February 20, 2006 at 7:08 pm
    If i create an animation like text in AE 7, is there a way to export it as true High definition so i can put it on a dvd in encore.
    Steve Roberts replied 20 years, 7 months ago 4 Members · 8 Replies
  • 8 Replies
  • Steve Freebairn
    February 20, 2006 at 7:15 pm
    Yes you can export an animation as HD, but encore doesn’t accept HD.
  • Mylenium
    February 20, 2006 at 7:17 pm
    Huh? Encore does not support HD authoring (and how should it, since neither the BDR nor HD-DVD specs are “nailed”) and if you just want a DivX clip on a disc, use Nero or whatever. Should you refer to uncompressed output, that can be easily done using a proper output module (the default one should be AVI uncompressed anyway on a Windows system).
    Mylenium
    [Pour Myl
  • Matthias
    February 20, 2006 at 7:43 pm
    should i just set my comp setting the project is in to 1080 by 720 resolution. And what format would be the best to export it as?
  • Mylenium
    February 21, 2006 at 6:23 am
    Just use the HD presets as they come with AE, so for HD 720 you need 1280 x 720 pixels, square pixel aspect. What format you use merely depends on what you’re going to do with it later on, but assuming you wanna achieve smooth playback on a computer, you should use H.264, Xvid, DivX or similar MPEG-4 based CoDecs. I would do the final compression in external tools such as VirtualDub (you have much more options there) and export only a mildly compressed clip from AE.
    Mylenium
    [Pour Myl
  • Matthias
    February 21, 2006 at 6:47 am
    I made my comp settings in ae 7 for my animation 1920:1080 but encore didnt except it, it only will except 720:480 as its highest resolution.
  • Steve Roberts
    February 21, 2006 at 2:22 pm
    That is because 720×480 is the only frame size available for a DVD. You cannot make HD DVDs yet. 720×480 is currently your only choice.
    Until the DVD spec is revised by those mysterious standards people. 🙂
  • Matthias
    February 21, 2006 at 9:22 pm
    if thats the case, then how would you put footage on a dvd you shot with the sony hdv camera that shoots with a 1920:1080 or 1080i resolution.
  • Steve Roberts
    February 22, 2006 at 3:27 am
    You’d drag it into a 720×480 DV-NTSC widescreen comp (use the preset when making the comp) or scale down the 1080 comp in the output module.
    BEWARE: 1) Because you’re scaling down the 1080 footage either way, you must separate fields (file>interpret footage>main) and 2) you cannot scale down in the output module if you are rendering with fields.
    I’d create the 720×480 widescreen comp and drag the big comp into that and scale it so it fits.
    NOTE: make sure your DVD-authoring app knows the footage is widescreen.
