Activity Forums Maxon Cinema 4D exporting an object, painting it, then re-apply texture
  • exporting an object, painting it, then re-apply texture
    Posted by Michael Duff on June 8, 2005 at 12:42 am
    I’ve got a plane, that has some holes in it that I made with booleans. Can I now export a flate version of this plane into photoshop, paint it, then import it as a texture. So I guess it would be similar to unwrapping a cube to make it flat, painting all the sides. Then importing the texture.
    Maybe bodypaint is made to do this? But I don’t think I have it.
    Michael Duff replied 21 years, 3 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    June 8, 2005 at 4:48 am
    You don’t really need BP for such a simple job. Just render the object from the top (or face-on, however it’s oriented). Then bring the render into PS and use it as a reference (BG layer) to paint your texture. Then load your tex in Cinema and flat map it onto your object.
  • Joe Bird
    June 8, 2005 at 6:57 pm
    As Adam says, this is probably a real east paint job, especially with flat mapping, but for those instances when more complex map painting is required, and you don’t have bodypaint, check out this tutorial from 3dKiwi: https://www.c4dcafe.com/portal/article_read.asp?id=18
    It utilizes a free program called UVmapper, and it works great!
    HTH
  • Michael Duff
    June 9, 2005 at 11:58 am
    Thanks, i will check out that link. My plane is not flat, it curves around a bit. So rendering the front view will not work. Hopefully this link will put me in the right direction
