Activity Forums Adobe Premiere Pro Exporting an EDL from Premiere
  • Exporting an EDL from Premiere
    Posted by Dorian Richmond on October 20, 2008 at 7:48 pm
    Is there a way to export a timeline from Premiere as an EDL in order to
    use it in another Premiere project? The dilema that I am facing is that there is some sort of corrupt file associated with a current project that is massive and made up of several timelines, and I want to break out just one of these timelines and re-capture the associated footage in an entirely new Premiere Pro project.
    Does anyone know how to accomplish this?
    Brad Foubister replied 17 years, 11 months ago 3 Members · 4 Replies
  • Brad Foubister
    October 21, 2008 at 10:07 pm
    I think I’m wanting similar information.
    I have edited 20 minutes worth of interviews.
    When I export (after rendering) just the edited interviews video & audio, I have no problem, but when I try to export them with titles, they crash and burn.
    In fact it’s done this a month with no luck to me resolving the problem.
    I was just wanting to (for example) copy the 20 minutes of interviews and start a new project and paste them back in to see if that works . . .
    Impossible?
    http://www.Studio-Era.com
  • Jon Barrie
    October 22, 2008 at 5:00 am
    If you have a corrupted prproj file from Premiere you can import it into a new project. Just import the .prproj project like any other media. If there are still problems you might have to delete the render folders as they may be causing the problems. But importing a prproj file is straight forward. You can then copy the seq you want to recapture. Start a new project. Paste, the seq and all bit involved will come in. Even if they are just offline files for a batch capture.
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Dorian Richmond
    October 22, 2008 at 12:30 pm
    Thank you. I’ll give that a try.
  • Brad Foubister
    October 22, 2008 at 4:41 pm
    And thank you both.
    That will help me take another run at my project here.
    Brad
