Activity Forums Maxon Cinema 4D Exporting an animation created in Marvelous
  • Exporting an animation created in Marvelous
    Posted by Mario Delauway on January 23, 2022 at 9:41 pm
    I created a dress in Marvelous. Then I exported this dress with the avatar in Alembic Ogawa format. This scene also contains a small animation, with 30 frames.
    When I import the Alembic Ogawa file into Cinema 4DR25, I only have frame 1 showing the avatar and the dress correctly. But I can’t see all the animation.
    I tried importing the same file into Blender which plays the animation correctly from frame 1 to frame 30.
    Apparently the file created by Marvelous is correct because Blender reads it correctly.
    I don’t understand why Cinema 4DR25 only shows frame 1.
    [Indirect method to solve this problem]
    Since Blender which correctly reads this Marvelous file, I exported the scene in Alembic format.
    Then I imported this Blender file into Cinema 4DR25 which this time was able to play all the animation correctly.
    So I manage to solve this problem through Blender.
    So it looks like Cinema 4DR25 can’t play Marvelous files in Alembic format correctly.
    Mario Delauway replied 4 years, 8 months ago 1 Member · 1 Reply
