Activity › Forums › Apple Final Cut Pro Legacy › Exporting an Alpha Channel
  • Exporting an Alpha Channel
    Posted by Cameron Yergler on June 16, 2009 at 6:22 pm
    Hello,
    I am working with a sequence that has the compression set to “none” and field dominance set to “lower (even)” in the sequence settings. I have a bit of text that needs to wipe on over picture, so I created the text in FCP and then keyframed “crop” located within the Motion tab to make it wipe.
    When it wipes, I can see the interlacing lines on the text. So, in the sequence settings, I set the field dominance to “none” and this took care of the problem. However, my picture now looked terrible.
    As a fix, I brought my text into a new sequence with compression set to “none” and field dominance set to “none” so I could export it and bring the quicktime back into the previous sequence with my picture.
    I set the export settings to Animation, but apparently no Alpha channel was exported because there was black behind the text when I brought it back into the sequence with my picture.
    Does anyone know how I can export an Alpha channel out of FCP that will work when I bring it back into FCP?
    Or maybe there is another solution I am overlooking.
    Thank you!!
    Tom Matthies replied 17 years, 3 months ago 3 Members · 2 Replies
  • Victor Perez
    June 16, 2009 at 9:05 pm
    Not sure why you are exporting your FCP made Text into a movie, but have you selected under Options in your export;
    Compression Type – Animation
    Compressor Depth – Millions of Colors+
    The + is for your alpha
    Now when you place your movie on top of video you should see it key thru
    Hope that helps,
    Victor
  • Tom Matthies
    June 17, 2009 at 2:08 am
    The trick to exporting from FCP with an alpha channel is export as animation millions+ and DO NOT RENDER YOUR CLIP. Export it unrendered. It should work.
    Tom
