Activity › Forums › Adobe Photoshop › Exporting an alpha channel for FCP?
Posted by Kay Nender on March 9, 2007 at 3:21 pmIs it possible to export an alpha channel from CS2 to FCP? The help files, they do nothing!
Michael Bugera replied 19 years, 6 months ago 2 Members · 1 Reply -
1 Reply
Michael Bugera
March 12, 2007 at 10:32 pmYes it is possible. I’m assuming you’re treating an image or text that you want to super over something in FCP.
Make sure the background layer is black. Go ahead and treat the image or text. If you have any drop shadow or other layer effects you’ll need to rasterize the layer before export. Once it’s ready, in the Layers Palette go to your image or text’s layer and right click (control click) on it and choose “Select Layer Transparancy”. Then go to the Channels Palette and choose “Save selection as channel”. This will give you a new channel, which is your alpha. Now go to “Save As…” in the File menu and save your selection as either a PICT or TIFF. (I used to only be able to save as a PICT but with CS2 I can also save as a TIFF. I don’t know why.)That should work!
Bugsy
