Activity Forums Adobe After Effects Exporting alpha
  • Exporting alpha
    Posted by Hannes Paulsson on September 22, 2010 at 9:34 am
    Hi!
    Ok, here’s the thing. I need to render a few things out from After Effects with Alpha.
    The client cannot premultiply when importing in their system, so I have to go with Straight alpha. What do I need to do in order for this to look right? We have the background that they will use.
    If i put black as my default background color and export the clip, it will get way to dark when i’ts imported with a straight alpha channel. Isn’t there a way to export it to get the alpha to look the exact same way when importing it to straight, as it would look if it was imported as premultiply with black?
    Hannes Paulsson replied 15 years, 12 months ago 35,667 Members · 1 Reply
  • Hannes Paulsson
    September 22, 2010 at 10:53 am
    Oops, forgot that you can choose “straight” when you export. Problem solved.
