Activity Forums Adobe After Effects Exporting alpha in TGA
  • Exporting alpha in TGA
    Posted by Ayas Hassan on April 29, 2006 at 10:23 am
    I have a serious problem…
    theres no alpha channel in TGAs that i exported from AE7
    i used millions of color+
    RGB+Alpha
    Straight (unmatted)
    i even tried changing th color setting to 16 bit and 32 bit…
    i also hav quicktime full installed in my machine
    can anyone solve my prob…
    i used to xport alpha in AE6.5 with out any probs
    thanx in advance
    Ayas
    Nirvana Digital Post FZ LLC
    Dubai Media City
    Donutz Mar replied 11 years, 6 months ago 5 Members · 8 Replies
  • 8 Replies
  • Joe Chao
    April 29, 2006 at 1:29 pm
    U might have some layers which have not an alphe channel.Check the alphe channel of you comp in AE, and you might found it. Pay attention to these layers. For example, a solid layer with some light effects(such as “lans flare”) on it ,and the transmode is “add” or “screen” or sth like that. these layers look like pictures with alphe channel, but in fact they don’t.
  • Ayas Hassan
    April 30, 2006 at 5:38 am
    thanx for th reply…
    ther is alpha channel in my composition… i even tried it with only a text layer.. but theres no alpha coming in th render.. any ideas?
    Ayas
    Dubai Media City
  • Joe Chao
    April 30, 2006 at 1:12 pm
    Sorry, I should have found it yesterday.
    here might be the problem:
    “i used millions of color+
    RGB+Alpha
    Straight (unmatted)”
    Straight (unmatted)???????
    I think it should be “Premultiplied(Matted)”:)
  • Steve Roberts
    April 30, 2006 at 1:45 pm
    Not necessarily. Apps that can see alpha channels can usually see either straight or premultiplied.
    Did you click “options” in the output module then select “32-bit”, not 24-bit”?
    If that doesn’t work, which app are you viewing the TGAs in?
  • Ayas Hassan
    May 1, 2006 at 5:42 am
    thanx steve..
    i tried rendering in 32 bit … but yet the same result
    but this time am getting an alpha layer in th channels palette in photoshop.. but that alpha doesnt work..
    i even tried using fcheck viewer that comes with MAYA..
    Ayas
    Dubai Media City
  • Allen Clements
    October 12, 2010 at 5:31 pm
    I am having the exact same problem. I’m trying to get a targa sequence with alpha into nuke. No amount of tweaking has helped. Was yours also with particular and a floor by any chance?
  • Allen Clements
    October 12, 2010 at 6:08 pm
    I wish it were so simple. I don’t think I’ve ever used “export” in AE. only the render queue…
    Using RGB+alpha. have tried 24 and 32bits (though 24 bit supports an alpha channel. shouldn’t make a difference.)
    I exported a quicktime movie in which the alpha channel worked… but i prefer working with frames. My 3D and higher end software has no problem with this.
    When I bring the targas into photoshop, sure enough, there is no alpha channel in the channels list.
  • Donutz Mar
    February 26, 2015 at 4:16 pm
    To export “*.tga” format with alpha channel you have to set your AfterFx project at 32 bit and set the render to:
    -32 bit
    -millions of color+
    -RGB+Alpha
    -Straight (unmatted).
    If you open your tga in photoshop you can find your “alpha” in channel tab.
    Create a selection of alpha channel with “ctrl+click” and apply it to your image in layers tab with “add vector mask”.
    I tried this in AdobeSuiteCC2014 and works well!
    Good luck! 😀
