Activity › Forums › Adobe After Effects › Exporting alpha channel as a mask
  • Exporting alpha channel as a mask
    Posted by Keiran O’brien on January 22, 2006 at 3:40 pm
    Despite searching the manual I am unsure how or if I can key out the green screened background from some live action video and then export the resulting alpha channel as a mask – either as an AVI file or image sequence (preferably both).I am using Version 6.5 Pro.
    Chris Smith replied 20 years, 8 months ago 3 Members · 3 Replies
  • Chris Smith
    January 22, 2006 at 4:37 pm
    Switch around the channels using one of the channel effects. So make the R, G, and B all equal alpha.
    Or create a white solid. Put the keyed footage one layer above it. Then set the white solid’s track matte to alpha.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Roland R. kahlenberg
    January 22, 2006 at 6:25 pm
    Hi Chris, wouldn’t setting the Output Module to render just the Alpha Channel do the trick?
    Cheers
    RoRK
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
  • Chris Smith
    January 22, 2006 at 6:41 pm
    haha. I suppose so. See what I get for never really getting to know the render module? The render module and I are 2 ships passing in the night. Did they hide the new color corrector and roto tools in the render module in AE7?
    Chris Smith
