Activity Forums Adobe Illustrator exporting ai file to TIFF in correct seize
  • exporting ai file to TIFF in correct seize
    Posted by Alexandre Brandt on August 29, 2012 at 9:04 pm
    Hello all,
    I’ve got an Ai file that is done on the DV PAL widescreen profile (1050 px by 576 px).
    I’m making a simple background for DVD menu done Apple DVD studio pro.
    Anyways, I’m trying to export this Ai file to TIFF but the output has a different resolution. Indeed, the export is 1067 × 730. I tried different formats like JPEG etc. its the same.
    My output settings are 72 ppi same as the profile settings when I made the Ai project.
    I’m wondering if there is something I’m missing or doing wrong in the workflow line.
    Thanks for your attention !
    motion pictures + storytelling = ?
    -> FILMMAKING !
    Alexandre Brandt replied 13 years, 8 months ago 2 Members · 2 Replies
  • Vincent Rosati
    August 29, 2012 at 11:29 pm
    You might have objects or effects outside the frame that are increasing the size. Maybe try applying clipping masks – if exporting from AI.
    Or you could just import the AI with Photoshop and set the Page Options to Media Box and the size should be correct.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Alexandre Brandt
    August 30, 2012 at 9:48 pm
    Great. The importing to Photoshop worked perfect. Thx.
    -> FILMMAKING !
