Activity › Forums › Adobe After Effects › Exporting AfterEffects Titles (with Alpha) to Avid Media Composer 2020
  • Exporting AfterEffects Titles (with Alpha) to Avid Media Composer 2020
    Posted by Evie Read on August 21, 2020 at 12:46 am
    I have created a title in AfterEffects with a transparent background, I have ensured that Alpha channels are selected in the render settings. AE is creating a .mov file which Avid is saying that it does not support. I have then made it an MXF via Resolve -this allows it to come into Avid successfully- however it appears on a black background and is no longer transparent.
    Please help.
    John Cuevas replied 6 years, 1 month ago 4 Members · 3 Replies
  • Roei Tzoref
    August 21, 2020 at 8:39 am
    you might want to ask that in the Avid forum it might be interpreting issue on the Avid side. if you export through After Effects, to make sure you export alpha correctly, export straight alpha, not premultiplied (with media encoder it’s always straight alpha so no worries there). also try importing the footage back to Ae and see that indeed it has alpha.
    Roei Tzoref
    2D/VFX Generalist & Instructor
    ♫ AeBlues Tutorials ♫
    http://www.tzoref.com
  • Eric Santiago
    August 21, 2020 at 1:07 pm
    Here is an old link using DNxHD/HR but still works https://community.avid.com/forums/t/93106.aspx
  • John Cuevas
    August 21, 2020 at 6:20 pm
    All of my co-workers use Macs have the same problem since recent Avid update. They are telling me that they can render from AE to .mov wrapper, but they have to link to the files, can’t import. Not sure why it’s different on PC, but I haven’t had this issue yet.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
