Activity Forums Adobe After Effects Exporting after effects layers to different AE project
  • Andy George
    November 16, 2009 at 10:07 pm
    Sanjeev-
    You can accomplish this by importing the after effects project with the layers
    you want to copy into the after effects project that you want to copy to.
    Then just copy and paste from one comp to another.
    If you don’t want to import the entire project check out the Reduce Project
    feature to reduce your first project to just the assets you would like to move.
    [Sanjeev Kumar] “and how do i ignore a layer in AE CS 4?”
    Im not sure if “ignore” is the correct term for this but if you turn off
    the eyeball icon on the layer in question, you will no longer see it and
    it will not interact with other layers.
    -Andy
  • Sanjeev Kumar
    November 17, 2009 at 4:05 am
    thanks i didnt knew we can export and import projects…
